Yeah I'm still just sitting back and waiting to see what happens. Right now my next one will be either the Manhattan or the Azbox Me......I'm just going to wait a couple of months to let the bugs get worked out..
Scott Greczkowski said:I was lucky enough to be sent a copy of the upcoming firmware and the Universal LNB 5150 / 10750 works on my LNB. I am now getting C/KU from my dish for the first time!
Yes, and it's identical to the mulitsat scan on Openbox. All selected sats are scanned.Can't you do a Multi Sat Scan?
I thought I misunderstood the issue. LOLRight now there is no 22k option in the motorized so this is the "workaround".
The reason that the blind scan is taking so long is that the receiver is being fooled into scanning 950-2150 with 22khz on then a second scan of 950-2150 with 22khz off. The actual IF frequencies that need to be scanned on either LNB is about half of that bandwidth.
huh? you are confused
It scans twice...once for C-Band and once for KU. I know the Manhattan (and the SSO's for that matter) scan 950-2150 regardless of LNB LO but its only scanning one band at a time
HUH??? No confusion here..... Correct, it is scanning only one band at a time, BUT.......
It scans 22khz - OFF for C-band (950 - 2150mhz) and again 22khz - ON for KU-band (950 - 2150mhz). This is just fooling the receiver into thinking that the LNB type selected is Universal with the built-in 22khz switch.![]()
and other than the fact if you scan say 91W you'll have both C-Band and KU Band under one satellite whats the issue?
Limited time offer
