What signals can you "see" at 61.5? | Page 2 | SatelliteGuys.US
3-7-08
1PM Eastern/Mostly Cloudy
Area: 11783 (Seaford, NY)
61.5 Dish Type :500
Receiver: VIP 622
1-NL
2-67
3-NL
4-71 NNA
5-59
6-NL
7-67 NNA
8-71
9-68
10-75
11-65
12-84
13-53
14-84
15-NL
16-69
17-62
18-73
19-68
20-52
21-61
22-55
23-77
24-65
25-80
26-NL
27-76
28-NL
29-77
30-48
31-75
32-66
rolou21....
3-7-2008 12: Noon CST
Area: 72653
61.5 Dish Type: 500
Receiver: Vip612 L4.72
NL=not locked
01 - NL
02 - 43
03 - 39 (Name not acquired)
04 - NL
05 - 39
06 - NL
07 - 125? NOT LOCKED(Name not acquired)
08 - 50
09 - 45
10 - 43
11 - 44
12 - 66
13 - 28
14 - 61
15 - 125? NOT LOCKED(Name not acquired)
16 - 49
17 - 41
18 - 48
19 - 49
20 - 35
21 - 43
22 - 36
23 - 56
24 - 46
25 - 53
26 - NL
27 - 52
28 - NL
29 - 48
30 - 28
31 - 50
32 - 45
On TP's 7 and 15 meter pegged at 125????
O'Fallon, IL 62269
61.5 Dish 500
VIP722
NL = Not Locked
7-Mar-08
11:55 AM
01 - NL
02 - 57
03 - 53
04 - NL
05 - 55
06 - 72
07 - 62
08 - 72
09 - 62
10 - 68
11 - 60
12 - 85
13 - 48
14 - 79
15 - NL
16 - 57
17 - 70
18 - 67
19 - 62
20 - 54
21 - 56
22 - 51
23 - 71
24 - 62
25 - 70
26 - NL
27 - 73
28 - NL
29 - 67
30 - 42
31 - 72
32 - 64
It is interesting that some folks are reporting signals on TPs 4, 6, 26 and 28. I thought that these were the TPs that E-3 couldn't provide signal from because of failures and that the E-12 satellite was not designed to use.
Taken 3/7/08 @ 12:15PM MDT
Area: 80439 (Evergreen, CO)
61.5 Dish type: Dish 300
Receiver: VIP 622 L4.49
1. NL
2. 47
3. 45
4. NL
5. 45
6. 55
7. 52
8. 55
9. 52
10. 50
11. 50
12. 69
13. 35
14. 64
15. NL
16. 53
17. 48
18. 48
19. 52
20. 40
21. 48
22. 35
23. 60
24. 56
25. 48
26. NL
27. 50
28. NL
29. 27
30. 28
31. 47
32. 46
Two transponders did something funny, e.g. TP 30. It locked in at 45, and then (sort of) "reset" (as in, dropped back to 0), and then "re-locked in" at 28. I repeated that behavior a second time. The third time I tested it, it simply went straight to 28.
Really bizarre.
Zip Code 27910, Dish 500, VIP 622 L4.48 5:15 pm, raining
1- 0
2-52
3-88 (Spot Beam)
4- 0
5-49
6- 0
7- 0
8-62
9-58
10-64
11-56
12-76
13-41
14-73
15- 0
16-59
17-52
18-63
19-56
20-45
21-51
22-49
23-64
24-55
25-70
26- 0
27-65
28- 0
29-67
30-42
31-64
32-53
FWIW, here are mine.
3-7-2008 2:30 PM Pacific
Area: 94080
61.5 Dish Type: 500
Receiver: VIP722 with L449
NL=not locked
01 - NL
02 - 53
03 - 50 (Name not acquired)
04 - NL
05 - 54
06 - 66 (Name not acquired)
07 - 62 (Name not acquired)
08 - 66
09 - 62
10 - 61
11 - 60
12 - 81
13 - 46
14 - 69
15 - 56 (Name not acquired)
16 - 65
17 - 56
18 - 58
19 - 62
20 - 50
21 - 56
22 - 43
23 - 70
24 - 63
25 - 59
26 - NL
27 - 66
28 - 34 (Name not acquired)
29 - 57
30 - 36
31 - 64
32 - 59
Lots of factors on the signal strength. For instance..is the Dish500 installed with the I-adapter to put the LNB full bore or is it just mounted in the 119 slot?
Is the signal meter level on all the VIP receivers calibrated to give the same readings if they were all connected to the same dish?
I believe that is the purpose of the new meters... I should think they would be within a few points of each other assuming all other things are equal such as cable length, quality of fittings, and such. What I don't know is what impact (if any) running simultaneous readings off the same dish will produce. If it is truly passive, then there should be no impact.
Anyone get better than low 30's signal on 61.5
I lost two HD channels in Puerto Rico
