jself1982 SatelliteGuys Pro Original poster Apr 15, 2006 1,272 0 South Carolina Dec 2, 2008 #1 I need the elevation, skew, and az. for zip code 29642 for a 75e star choice dish, but I am not using it for HD so the stats for 107.3 should work. Thanks
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,557 15,457 Mankato, MN Dec 2, 2008 #2 if its the quad LNB you still need to set for 111.1 as that is the LNB directly down the arm info from thelist 111.1°W Anik F2 C/Ku 39.5° elevation 231.4° azimtuh 34.5°L skew...take this number from 90...left side (if bwhind the dish) is higher than the right side
jself1982 SatelliteGuys Pro Original poster Apr 15, 2006 1,272 0 South Carolina Dec 3, 2008 #3 Got it! Had to do a factory reset on the 305 before it would work, but I got it!
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,557 15,457 Mankato, MN Dec 3, 2008 #4 cool...glad its working
