Power Inserter | SatelliteGuys.US
Power Inserter
lee vitalone
14
here
Big question, For the slimline hd with the single lnb a power inserter is required, (swm) We have one that is 21v and we suspect it should be 29v. This may be why we cannot obtain a signal?
Is it a SLIMLINE or a SWM SL dish ?
If it's NOT a SWM, no Power Inserter used.
The LNB should have only 1 output if it's a SWM set up.
29v is for a swm8/16/32 multiswitch. Some techs use them if the dish is more than 200' from the pi however. But generally u wanna use the 21v
Sent from my PG06100 using Tapatalk 2
Thank You! having a heck of a time with this guy. bought a meter to help us. we think we caught a bad lnb.
You can always use the 29 volt model. The 21 volt one should only be used with a swm lnb, not a swm switch.
blackout on MLB Network
I just want to say "I LOVE DIRECTV"
