sorry my bad. the file was hosted off site. and it doesnt fix my youtube. still stuck at loading. but my channellist survived the new software so i aint touching it.
crackt out,.
crackt out,.
I also notice that the newest 4890 firmware says "fixed recording problem". This made me wonder whether perhaps the high bitrate recording issue has been addressed? I know, wishful thinking, but I'm curious whether anyone who has put on the new 4890 has tried to record any high bitrate feeds?
I just loaded 4890, tested on CBS DVB-S2 4:2:2, it did not record perfect, but it was better than previous.
ABC HD recorded fine.
If you couldn't record ABC-HD previously that's good news.
With version 9.4890 of the firmware I'm able to record the NBC high def feeds from AMC1.
But only with hardware acceleration enabled. I hope the over clocking doesn't let the smoke out of it.
When you say it works with accelertion turned on, are you referring to recording, playback or both?
I'd say that's good news and bad news. Its good news that it now works although it also seems to indicate that cpu in these boxes is underpowered for high bit rate feeds. I wonder how much the processor is being overclocked, 3%, 5%, 10%, etc? I have an Ultra and its hard to imagine that there is much of a heatsink and/or much airflow. If acceleration does give it stability for recording HD feeds, adding a larger heatsink/fan should probably be considered if the box becomes unstable.
Limited time offer
