Moving the receiver help requested | SatelliteGuys.US
Pauli2000
MI
Hello,
I need to move the receiver. Currently, it is wire with 2 cable from the dish to a pair of B band converter modules the into the receiver. What I need to know is can I use a combiner to combime the 2 cables make the run to the new location using RG6 cable then use a splitter and the B band modules to connect the to the receiver? The RG6 is already installed in the wall with no possibility of adding another cable. Also I have 2 DP Plus splitters, 123254, could I use these to do the combining and splitting?
Thank you,
Paul
DTV installer will not use existing RG59 runs
DIRECT TV HD BOX TO COAX
