FYI: My 1.0M CM takes round struts and this CM-B1 LNB holder ($16.99) from prosat looks like a good fit:
...my wife hated that thing, but I absolutely loved it...
I checked out the URL
Do they sell the three feed support arms?
Better yet does any one have the the feed support arms they want to part with? I only need one.
The bottom one.
That dish looks like my 1 meter Prodelin. Here are some pics of the lnb bracket and such.
The dish came with a manual: 4096-433 Assembly Manual for Small Aperture Ku-Band Rx/O Antenna System, Rev B. 1997. I think that's the part number for the small aperture mount for the 0.6 through 1.0 meter dishes...
Part numbers for the bracket are:
4080-060 Top Feed Clamp
4080-059 Feed Mounting Bracket
FWIW.
If that plastic bracket doesn't work out you might get this prime focus adapter from Sadoun, stick it in a vise, bend it as necessary, and drill a couple of 1/4" holes for the arms if necessary. YMMV
EDIT: BTW, the feed mouth is about 27" - 27.5" from the face of the dish as measured from a point halfway between the side arm mounting points...
since he hasnt logged on in almost a year I dont think he'd see this thread![]()
Limited time offer
