Huntsville, AL Locals Question | Page 3 | SatelliteGuys.US
Do you have the other 3 HSV locals in HD thru Dish on the 61.5? If so, how is the quality?
I do get WAFF-HD NBC, WHNT-HD CBS, and WZDX-HD FOX from a second dish pointed at 61.5.
As reported previously in this group, I find the 1800i NBC and CBS pictures a little softer than OTA due to DISH reducing the bitrate from what is broadcast.
The FOX 720p looks the same as OTA. They don't reduce the bitrate.
It appears WAAY-HD ABC will be added soon. :up
lowdown
I am 35 miles from Huntsville. I have talked to the station manager and to a supervisor at Dish Network about this problem. Channel 31 station manager told me that they are uplinked, and it is Dish Networks problem. Dish told me that they were not uplinked. I got tired of the lies, so I bought me a new over the air antenna to pick up all of the HI Def channels from Huntsville. I have a great picture. I hooked the coax from the antenna to my 622 box and now the guide is displayed and I can use my DVR with the channels. Where I live I can also pick up the Florence channels at 80% without moving my antenna.:)
It wasn't uplinked with the rest.
Found it!!
UPLINK ACTIVITY: SAMPLE 04-09-2008 13:56:56 TO 04-09-2008 13:59:00 ET
Code:
[SIZE=2][B]135 ADD(S)[/B][/SIZE]
[SIZE=2]ADD 574 FPCHN MPEG2 SD Tp 10 EchoStar 3 61.5w [B][COLOR=teal]AVAIL[/COLOR][/B] HIDE[/SIZE]
[SIZE=2]ADD 5150 WTVC{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 9[/SIZE]
[SIZE=2]ADD 5151 WDEF{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12[/SIZE]
[SIZE=2]ADD 5152 WRCB{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3[/SIZE]
[SIZE=2]ADD 5153 WDSI{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 61[/SIZE]
[SIZE=2]ADD 5160 WMAR{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 2[/SIZE]
[SIZE=2]ADD 5160 WVNY{BURLINGTON, VT} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 22[/SIZE]
[SIZE=2]ADD 5160 WATE{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6[/SIZE]
[SIZE=2]ADD 5160 WEAR{PENSACOLA, FL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3[/SIZE]
[SIZE=2]ADD 5161 WJZ{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13[/SIZE]
[SIZE=2]ADD 5161 WCAX{BURLINGTON, VT} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3[/SIZE]
[SIZE=2]ADD 5161 WVLT{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 8[/SIZE]
[SIZE=2]ADD 5161 WKRG{MOBILE, AL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5[/SIZE]
[SIZE=2]ADD 5162 WBAL{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 11[/SIZE]
[SIZE=2]ADD 5162 WPTZ{NORTH POLE, NY} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5[/SIZE]
[SIZE=2]ADD 5162 WBIR{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10[/SIZE]
[SIZE=2]ADD 5162 WPMI{MOBILE, AL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 15[/SIZE]
[SIZE=2]ADD 5163 WBFF{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 45[/SIZE]
[SIZE=2]ADD 5163 WFFF{BURLINGTON, VT} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 44[/SIZE]
[SIZE=2]ADD 5163 WTNZ{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 43[/SIZE]
[SIZE=2]ADD 5163 WALA{MOBILE, AL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10[/SIZE]
[SIZE=2]ADD 5164 WJTC{PENSACOLA, FL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 44[/SIZE]
[SIZE=2]ADD 5190 WTEN{ALBANY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10[/SIZE]
[SIZE=2]ADD 5190 WLOS{ASHEVILLE, NC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13[/SIZE]
[SIZE=2]ADD 5190 WAAY{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 31[/SIZE]
[SIZE=2]ADD 5191 WRGB{SCHENECTADY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6[/SIZE]
[SIZE=2]ADD 5191 WSPA{SPARTANBURG, SC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 7[/SIZE]
[SIZE=2]ADD 5191 WHNT{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 19[/SIZE]
[SIZE=2]ADD 5192 WNYT{ALBANY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13[/SIZE]
[SIZE=2]ADD 5192 WYFF{GREENVILLE, SC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 4[/SIZE]
[SIZE=2]ADD 5192 WAFF{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 48[/SIZE]
[SIZE=2]ADD 5193 WXXA{ALBANY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 23[/SIZE]
[SIZE=2]ADD 5193 WHNS{GREENVILLE, SC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 21[/SIZE]
[SIZE=2]ADD 5193 WZDX{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 54[/SIZE]
[SIZE=2]As you can see, WAAY was first uplinked on 4-09-08, along with the rest of our HD locals. [/SIZE]
WAAY-HD is and has been uplinked as long as the other 3 stations in HD have been.
All DISH has to do is flip the switch but WAAY has to say you can.
I call shenanigans on all the finger pointing from both sides. :up
OK, according to the last uplink report WAAY was moved to 61.5, I'm seeing it on 110. Yes I do have a wing dish. I've done a check switch, reset receiver. It still showing on 110. Any ideas?
Looks like from the uplink report WAAY will be turned on soon...it's been up there since 4-09-08.
Yes and no.
WAAY-DT HD was uplinked for a time, but they never came to an agreement. DISH finally removed WAAY-DT HD. It was never available to subscribers.
If they have recently started to uplink WAAY-DT HD that is a good sign it may show up soon. :up
lowdown
DISH Failed Digital TV Test 12/17/2008
Dish failed the Huntsville digital TV test at 5:25pm on December 17, 2008.
I did the split screen on the VIP722 with TV1 on the DISH HD WAFF-DT feed and TV2 on the DISH SD WAFF feed.
The HD feed was fine. The SD feed got the message about not being ready and to call some number or log on to some website.
I thought DISH was supposed to get the digital feeds in November.
I am sure they will get it taken care of before Feb. 17, 2009.
Maybe. :rolleyes:
lowdown
commercial volume out of control
6.3 IR/UHF PRO remote not working with new tv
