I did about a month ago, no answer.
Do you have the other 3 HSV locals in HD thru Dish on the 61.5? If so, how is the quality?
I believe it was back in April when 19, 48, and 54 went up, WAAY was uplinked, just not available.
It wasn't uplinked with the rest.
Found it!!It wasn't uplinked with the rest.
[SIZE=2][B]135 ADD(S)[/B][/SIZE]
[SIZE=2]ADD 574 FPCHN MPEG2 SD Tp 10 EchoStar 3 61.5w [B][COLOR=teal]AVAIL[/COLOR][/B] HIDE[/SIZE]
[SIZE=2]ADD 5150 WTVC{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 9[/SIZE]
[SIZE=2]ADD 5151 WDEF{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12[/SIZE]
[SIZE=2]ADD 5152 WRCB{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3[/SIZE]
[SIZE=2]ADD 5153 WDSI{CHATTANOOGA, TN} MPEG4 HD Tp 3 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 61[/SIZE]
[SIZE=2]ADD 5160 WMAR{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 2[/SIZE]
[SIZE=2]ADD 5160 WVNY{BURLINGTON, VT} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 22[/SIZE]
[SIZE=2]ADD 5160 WATE{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6[/SIZE]
[SIZE=2]ADD 5160 WEAR{PENSACOLA, FL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3[/SIZE]
[SIZE=2]ADD 5161 WJZ{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13[/SIZE]
[SIZE=2]ADD 5161 WCAX{BURLINGTON, VT} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3[/SIZE]
[SIZE=2]ADD 5161 WVLT{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 8[/SIZE]
[SIZE=2]ADD 5161 WKRG{MOBILE, AL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5[/SIZE]
[SIZE=2]ADD 5162 WBAL{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 11[/SIZE]
[SIZE=2]ADD 5162 WPTZ{NORTH POLE, NY} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5[/SIZE]
[SIZE=2]ADD 5162 WBIR{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10[/SIZE]
[SIZE=2]ADD 5162 WPMI{MOBILE, AL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 15[/SIZE]
[SIZE=2]ADD 5163 WBFF{BALTIMORE, MD} MPEG4 HD Tp 9 Spot 15 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 45[/SIZE]
[SIZE=2]ADD 5163 WFFF{BURLINGTON, VT} MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 44[/SIZE]
[SIZE=2]ADD 5163 WTNZ{KNOXVILLE, TN} MPEG4 HD Tp 7 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 43[/SIZE]
[SIZE=2]ADD 5163 WALA{MOBILE, AL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10[/SIZE]
[SIZE=2]ADD 5164 WJTC{PENSACOLA, FL} MPEG4 HD Tp 3 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 44[/SIZE]
[SIZE=2]ADD 5190 WTEN{ALBANY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10[/SIZE]
[SIZE=2]ADD 5190 WLOS{ASHEVILLE, NC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13[/SIZE]
[SIZE=2]ADD 5190 WAAY{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 31[/SIZE]
[SIZE=2]ADD 5191 WRGB{SCHENECTADY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6[/SIZE]
[SIZE=2]ADD 5191 WSPA{SPARTANBURG, SC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 7[/SIZE]
[SIZE=2]ADD 5191 WHNT{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 19[/SIZE]
[SIZE=2]ADD 5192 WNYT{ALBANY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13[/SIZE]
[SIZE=2]ADD 5192 WYFF{GREENVILLE, SC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 4[/SIZE]
[SIZE=2]ADD 5192 WAFF{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 48[/SIZE]
[SIZE=2]ADD 5193 WXXA{ALBANY, NY} MPEG4 HD Tp 3 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 23[/SIZE]
[SIZE=2]ADD 5193 WHNS{GREENVILLE, SC} MPEG4 HD Tp 1 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 21[/SIZE]
[SIZE=2]ADD 5193 WZDX{HUNTSVILLE, AL} MPEG4 HD Tp 11 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 54[/SIZE]
[SIZE=2]As you can see, WAAY was first uplinked on 4-09-08, along with the rest of our HD locals. [/SIZE]
Looks like from the uplink report WAAY will be turned on soon...it's been up there since 4-09-08.
Limited time offer
