Be glad you aren't trying to watch on a WJ - using Carbon203 it "updates" without a Y/N option, just abrupt black screen, then 25 min later it does it again because it loses Moca when the H2 does it's update. Will be relocating my H3 install so that the WJ is in the LR, don't watch late night tv there.Reintroduce the feature of having the daily/nightly updates at whatever time you want it to update. I hate the mandatory 1 AM time for the updates as I stay up very late and watch TV at that time and don't to stop watching my shows just to do a update.
Sent from my RCT6773W22B using Tapatalk
My HWS did the same thing most nights - no warning whatsoever. I'm hoping the H3 won't do the same but the jury is still out...Be glad you aren't trying to watch on a WJ - using Carbon203 it "updates" without a Y/N option, just abrupt black screen, then 25 min later it does it again because it loses Moca when the H2 does it's update. Will be relocating my H3 install so that the WJ is in the LR, don't watch late night tv there.
Its there, after you select your search result you'll see a selection of "record when availible"
I'd like to see a channel guide that can be sorted alphabetically or in a custom order.
I'd like PIP to remember that I like the PIP box to be in the bottom right corner instead of always appearing in the top right.
That's it. I like everything else.
Anyone have the Carbon UI on their Dual HWS setup?
Sent from my SAMSUNG-SM-G900A using Tapatalk
How is it operating overall?Yes.
I can answer that one, I found it by accident.
Edit: It remembers it during a session, but I found that an H3 restart or the nightly update, seems to reset it to the top right.
That's why I upgraded to H3, much simpler to have everything on one Hopper. Tried the Carbon (manual install of 203) & found between Hoppers it was very slow & was showing a black screen at first, once connected it seemed to work OK. I was still getting nightly update reminders, so far with New H3/J2 I'm not getting the interruptions so either the new equip makes a difference or there's something different in the software.I would love to see Dish add the option to see and edit the other hoppers timers. I have 2 Hoppers and It would be a nice feature. Or even an option to create a timer on another hopper from the guide.
One more year, Then I'll do the upgrade.That's why I upgraded to H3, much simpler to have everything on one Hopper. Tried the Carbon (manual install of 203) & found between Hoppers it was very slow & was showing a black screen at first, once connected it seemed to work OK. I was still getting nightly update reminders, so far with New H3/J2 I'm not getting the interruptions so either the new equip makes a difference or there's something different in the software.
I'll do it eventually. But right now I'm hopping the new UI gets a little more profected.$2 less in fees for me, so no brainer, though if it goes down I don't have OTA & will have to resort to streaming for a few days. It's actually hard to adjust, keep finding myself wanting to switch to the recordings on the other Hopper![]()
Limited time offer
