Menu, Prime Time, Options, Group By, Network....They need to bring back the folders by network for the PTAT screen.
Well that was cleverly hidden.Menu, Prime Time, Options, Group By, Network....
You forced the update ? If so, I must say I'm surprised...Menu, Prime Time, Options, Group By, Network....
Its there, after you select your search result you'll see a selection of "record when availible"Did we lose "Seek and Record" timers? Don't see any option to create one.
Well that creates a timer with a long alpha/numeric number then a colon and the game title. If you check the timer schedule then it shows nothing set to record. However, if you search for "Arkansas Razorbacks", for example, then it breaks out all the different sports they are playing. I selected the men's basketball and it gives an option to "Record All Games"!Its there, after you select your search result you'll see a selection of "record when availible"
Does this only work on the H3 and not an HWS w/Carbon UI? I can't find this....From memory, go to DVR, PTAT, Options, Select Group, Select Group by Network.
Tada!![]()
I'm not sure I understand - what would be the difference between "sort by date" and "sort by new"? I thought that date sort put the new first?Just updated to CarbonUI for first time. One suggestion I would recommend is having a way to sort recording by - NEW. This way all your new recordings are at the top of your recording list along with the current Sort by Date and A-Z.
I checked on the Hopper with Sling as well and didn't see it. Must be an option added in the Hopper 3 software that we don't have (yet).Does this only work on the H3 and not an HWS w/Carbon UI? I can't find this....
It's there.Does this only work on the H3 and not an HWS w/Carbon UI? I can't find this....
Limited time offer
