Actually a red button reboot does not download the guide. You have to do a hard reset (unplug the box) to get the guide to download. Yes, that's the first thing I did before calling tech support.
I never understood why Dish never included a guide download option somewhere in their menus. It seems it wouldn't be that difficult and would eliminate the necessity of unplugging the receiver.Actually a red button reboot does not download the guide. You have to do a hard reset (unplug the box) to get the guide to download. Yes, that's the first thing I did before calling tech support.
On the ViP or older receivers, if you scrolled all the way to the right in the Guide, it would give you the option to do a guide download if the Guide was outdated.I never understood why Dish never included a guide download option somewhere in their menus. It seems it wouldn't be that difficult and would eliminate the necessity of unplugging the receiver.
I am not sure about other models of Hoppers, but on both the Hopper Duo and Wally, the power cord is detachable from the back of the receiver. In other words, if you have access to the back of the receiver to be able to change cables, then there is an easy way to unplug it without having to trace the power cord and find the proper plug in the outlet. I have rebooted my Hopper Duo and Wally that way more than once with no ill effects, so it does not seem to matter which end of the cord you unplug.And if you can't make it easy to download the guide why the hell is the power cable hard wired? LOTS of Hoppers if not most are buried deep in equipment cabinets which makes it VERY difficult to get to the power plug. Since a hard reboot is a problem solver I've put a switchable extension cord on the Hopper after having to dismantle my cabinet a few times . . . It would be nice if the people who designed these things actually lived with them.
I wish I knew where I could test some tubes- err, "valves." If I could get replacements it might bring my Kuba back to life.
The Hopper 1 and Hopper 3 that I am in possession of have hard wired power cords. No way to unplug it at the receivers.On the ViP or older receivers, if you scrolled all the way to the right in the Guide, it would give you the option to do a guide download if the Guide was outdated.
I am not sure about other models of Hoppers, but on both the Hopper Duo and Wally, the power cord is detachable from the back of the receiver. In other words, if you have access to the back of the receiver to be able to change cables, then there is an easy way to unplug it without having to trace the power cord and find the proper plug in the outlet. I have rebooted my Hopper Duo and Wally that way more than once with no ill effects, so it does not seem to matter which end of the cord you unplug.![]()
I thought I remembered that about the Hopper 1, but I was not sure. In any event, my point is that this is one thing that Dish got right when they were designing the Wally and the Hopper Duo.The Hopper 1 and Hopper 3 that I am in possession of have hard wired power cords. No way to unplug it at the receivers.
When the timer fails to record, does the event show up in the Schedule tab when you go back to look at that day's activity? If so, does it say "Not Applicable" for that event on the right side of the screen, where it gives the details for "Recording Started" and "Recording Stopped"? Were you also recording anything on a different OTA channel and/or satellite-delivered channel(s) at the same time as the timer that failed? What is the code number in the upper-right corner of the signal lost error message you are seeing? What you described sounds very similar to an issue that I have experienced, and I have also read about others who have experienced the same problem.I'm not sure if it's related to some of the guide problems mentioned but I've been experiencing a problem lately with one of my OTA stations. Twice in the last few weeks timers I had set on our local CBS affiliate WISC 3.1 failed to record anything. When I looked at the channel in the guide it was listed and showed the red recording in progress light but nothing showed up in the DVR. Tuning to the channel only got a OTA signal lost error message even though I have an outside antenna and all channels show 100% signal. Re-scanning the OTA locals seemed to fix the problem for about a week but then it happened again.
Here it is. I posted a link earlier in this thread, but I will post one again here, just to make it convenient:When the timer fails to record, does the event show up in the Schedule tab when you go back to look at that day's activity? If so, does it say "Not Applicable" for that event on the right side of the screen, where it gives the details for "Recording Started" and "Recording Stopped"? Were you also recording anything on a different OTA channel and/or satellite-delivered channel(s) at the same time as the timer that failed? What is the code number in the upper-right corner of the signal lost error message you are seeing? What you described sounds very similar to an issue that I have experienced, and I have also read about others who have experienced the same problem.
One tuner of dual OTA adapter keeps going "dead." - mydish communities - 12560
Limited time offer
