If the Lark is the one Dish sells, the electronics are identical, so it is a matter of case color preference.
...and price. For me, the AirTV adapter is better in both categories.If the Lark is the one Dish sells, the electronics are identical, so it is a matter of case color preference.
It works in the USB2 port on the Hopper 3 so I'm gonna guess it's USB2.Does anybody know whether it's USB2 or 3?
Do you know if the white AirTV adaptor works with the Wally?...and price. For me, the AirTV adapter is better in both categories.
Yes, it does.Do you know if the white AirTV adaptor works with the Wally?
Ok, good. I'm trying to get that to work, but it's doing nothing. Quick question: my adapter has 2 nicks on the edge that appear to be lights. If so, do they light up when you plug it into the USB port?Yes, it does.
You have the wrong adapter. You need the one with the wire coming out with the USB plug on the end. Products | AirTV
That clears things up. I'll order the right one tonight. Thank you, Bobby.You have the wrong adapter.
Limited time offer
