This is c/p from dish pointer"My above comment pertains to your true south satellite. (Motorized systems are trickier)
That was yesterday. weather was a bit mild. now is cold.How can you be doing this stuff in this bitter cold?? You are braver than I!
So, where should I count the 6.5° declination: to the dish or the motor ?Once you get the motor angle right you then adjust the dish angle (declination) to that it aims at the satellite which is about five earth radii away and above the equator. If the distance to the satellite was infinite the declination would be zero but because the distance is about five earth radii there must be a 6.5 degree declination angle.
What is "Elevation:41.2°" for, if the dish elevation is already set @ 38°?That is accounted in the Dish Elevation, so just set the Dish to the recommended Elevation for you location and motor.
Motor Latitude: 42.3°
Dish Elevation: 38°
Elevation: 41.2°
Azimuth (magn.): 187.5° (compass)
Limited time offer
