Things we do for clear reception | SatelliteGuys.US
Comptech
3,678
2,844
Travelers Rest SC
As you all know I have a tree problem. I decided to drop a 40 foot weed tree today, Lcals call it a bush berry, but anyway a hollow center and taking over the back of the house. Trunk is 20 feet down a steep grade and the top of the tree clears my two story house. I used to come alongs tied to bigger trees to pull it in a direction, but i will be damned, that SOB twisted and landed on the house. no damage to the house, but mangled my antenna farm.
I've done that myself with the come-alongs. The issue with doing it that way, is as soon as the tree is cut far enough to release some tension on the wire rope from the come-along, the tree can then twist anyway it wants to either side, instead of in the direction your come-along is pulling from.
So, the trick is to continue to WEDGE the tree as you cut it slow at first (good wedges, and at least a 4lb hammer or sledge to drive them), and make the last cut VERY FAST. If you do it that way and wedge it right, it's nearly impossible for it to do a sudden reverse twist.
Now you tell me! Just glad I am here to bitch about it.
Look on the bright side: Now you get to do a little research, and get some new antennas!
I suggest Televes Dat Boss, BUT, we'd really need to see a Rabbitears report to advise you as to which model would be your best bet. Run the report and post the results link here: RabbitEars.Info
Here's 3 - 90' maple trees that a tree service took down in our neighborhood yesterday. They used 1 60' and 1 90' High Rangers
The COOLEST thing, is that these tree's were 475' in the direct path inline that my antenna was aiming at. So, it opened up a better window to 3 of my main stations. I'd bet this was around a $20k job, as they were only a few feet away from his house... Also, YES, those are power wires directly under the tree.
Reactions: catamount
Last fall I rented a 55' diesel lift to cut down trees and limbs. Been a long time since I was in a harness and hard hat but about half as expensive as hiring a tree service. Still cost me about $1700 to rent that lift for three days though.
Reactions: c-spand and AZ.
Website of Satellite Backhaul wild feeds?????
Usb satellite card
