I need to make a better "list" of the ones I am getting and or compare with the TVFOOL report, that and the real/virtual channels still are confusing to me. But I'm pretty sure I am not receiving the ABC stations to this point. I'm pretty sure that's the only major I haven't seen yet, that and it's side channels. I'm not sure why it wouldn't be coming in... growing up it always seemed one that came it well VS the KPTS or CBS.
My guess is it's because ABC is a VHF channel and those are often more difficult to pull in. KAKE also simulcasts on UHF 21, but it's only 15 kW, and at your distance from the towers it's probably not strong enough to come in.
When we were kids back in the analog days, VHF worked much better.
I see!Well the 2nd antenna I was anticipating is indeed a VHF only and maybe that's what will solve this problem. So do you suppose I'm not receiving any VHF at this point, as the only other VHF stations at this point I am receiving, but they both also have UHF. I guess I just need to pay more attention and figure out what's happening with it....
How is it that in such a topographically challenged state as Kansas that so many OTA hopefuls have multiple edge reception issues?
The area around Whichita appears to vary by less than 500' for at least 100 miles in every direction. It appears that things don't get particularly interesting until you get close to Colorado (much as Texas doesn't get interesting until you get close to New Mexico).It's a common misconception that Kansas is flat.
Oregon, for example, varies as much as 11,000' in 120 miles (Sea Level to the summit of Mt. Hood).
How many TVs total?
Insertion loss for a properly install coupler is around 0.1dB.
I am currently split to only 2 TVs. Some day if I find the need I could change to a 3-way and feed a 3rd TV. And might do it anyway just to experiment one of these days. BTW the TV that gets worse reception is also the line that I am inserting power into. Not sure that matters just pointing it out in case.
So I'm guessing if the coupler is properly installed you are saying it's probably not causing the lack of reception...?
My residence falls into the edge of an area in Kansas and Northern Oklahoma called the Flint Hills.
Flint Hills - Wikipedia
All I guess it takes is to be one of the unlucky ones that is at the bottom of one of the Flint Hills. Like me who then have all the 1 or 2Edge signals.... Consequently anyone not in the Flint Hills or is living further west towards Colorado gets to see their dog for days as it runs away from home!!
All of the hills look pretty random when you are too close to the earth... but get the correct view from a commercial airliner and you start to see the hills aren't so random. In fact you'll see that view reminds you of looking at the veins in a leaf. They all follow suit in the picture as a whole!
Sounds like you're having good success! The Stellar Labs 30-2476 is a very good VHF antenna. I have the same model. Keep us posted on your final channel tally![]()
It is that relatively gentle ascent that makes it "uninteresting".Hays Kansas is 2000 feet. You start climbing once you get west of Topeka.
I would guess that the insertion loss isn't much more than that of a coupler. Getting a whole other level of stations suggests that there may be other compromises (additional splitters?) in the line or the tuner really is that poor.TW the TV that gets worse reception is also the line that I am inserting power into. Not sure that matters just pointing it out in case.
Doesn't seem likely unless it is defective (I've seen couplers that came without any center connector) or there has been moisture in in the cable or connection that have messed with the impedance.So I'm guessing if the coupler is properly installed you are saying it's probably not causing the lack of reception...?
I would guess that the insertion loss isn't much more than that of a coupler. Getting a whole other level of stations suggests that there may be other compromises (additional splitters?) in the line or the tuner really is that poor.Doesn't seem likely unless it is defective (I've seen couplers that came without any center connector) or there has been moisture in in the cable or connection that have messed with the impedance.
I'd try getting a fresh 100' cable and running it through doors or windows direct from the splitter (or preamp output if convenient) to the theater tuner and see if your theater room channel count improves.
Limited time offer
