Incentive Auction Discussion | Page 26 | SatelliteGuys.US
No matter how u receive they say we will all pay Atsc 3,0 ,! will be the way to go no one knowns yeat FCC gives!! green light !!!ATSC !!!3.0 testing ? Look for them signals you might find some broadcasting going on!!
Reactions: jamesjimcie
I red some where they say a real good indoor antennas will work well.I don't think so maybe if you are close to tower's 25/35miles with low vhf ,
Most indoor antennas don't work well with VHF low unless they're old school.
Most of the mud flaps (fractal antennas) are designed primarily for UHF and you're doing good to dip into VHF high. Rabbit ear antennas may prove superior due to their ability to capture longer wavelengths.
Reactions: Nascarken 91xg
But you are rong about that state of the art on the tower's now a days just a flick of the switch, o yes!!!!!!!
You are wrong. Physics doesn't change with newer technology.
As the article makes clear, getting the same coverage pattern at different frequencies requires antenna modification and a change in power. You're assuming that you can use the same amplifier and depending on how far the move in frequency is, that may not be possible. Anyone moving from UHF to VHF will likely need a completely different transmitter, antenna(s) and a new elevation; perhaps on a different tower. None of these is a matter of flicking a switch.
Just as it is with your 91XG that is UHF-only, stations going to VHF (whether high or low) will have to do something entirely different to work with the VHF band where the wavelengths are much longer. The wavelength of RF13 is about 55.77" while the wavelength of RF14 is about 25.12" (less than half). The wavelength of RF2 is upwards of 17'.
This isn't entirely correct. KMJC, which is about 9 miles from my house, just came on the air last Fall, and their transmitter is ATSC 3.0 ready. I've been inside the station and visited with the engineer, who told me they are ready. So, while most stations probably aren't ready to go, some of the newer ones might be. There's a thread in the OTA forum with photos in case you're curious.
The transmitter doesn't much care what the modulation scheme is as long as the data fits in the pipe. The transmitter cares about its frequency and a nice steady input stream. This is a common misconception in the DBS forums where a surprising number of participants errantly believe that there is such a thing as an "HD satellite". I guess this also applies in the OTA forums where some believe that "HD antenna" or "digital antenna" has meaning. :(
The other side of that coin is that KMJC could move their DTV broadcast to a different setup and hit the ground running with the existing setup using ATSC 3.0. I would imagine there's going to be some excitement in the market for refitting transmitters to broadcast on lower frequencies than they were originally designed for.
Well for your info harsh my 91xg yes is UHF and my other haf is a hi&low wine 8200u and when you put the two antennas together work quite well ! The 91xg took over the UHF part of the 8200u, signal of 70% no dropouts
Vh
Vhf part is the same 70% go fish!!!¡!!
And Zzzzzip your Lip's, thanks,,,,,,
Well, with everything beyond RF36 being cut for tv stations, IF you aren't going to have any channels higher than RF35 in your area, we can use these for LTE filters on our tv antenna systems. They don't pass anything above 600mHz:
Amazon product ASIN B00006JPE6
Trip, on what date will the FCC announce the repack assignments?
I am not trip so perhaps I should keep my mouth shut but all I have ever read is mid April. Not sure if that means as close as possible to the 15th or perhaps anytime from the 10th to the 20th.
Ion is now available OTA in Fargo
H&I and Retro TV to move to KJWP
