Meter for Pointing an OTA antenna | Page 2 | SatelliteGuys.US
The above only show signal strength. Not very useful for optimizing signal quality for reliable reception.
I use a SiliconDust tuner and SiliconDust HomeRun Meter app on an Android tablet.
https://play.google.com/store/apps/details?id=com.zaren
There is also one for Iphone called Signal GH. It's $2.99. Allows you to view signal strength AND signal quality for two channels at the same time. I've used it when on my roof trying to aim my antenna. VERY useful. Also plots the location of the towers and your GPS location so you know where to aim
Reactions: rglore
The best meter you can use is a small tv. My meter can't find two signals that I do receive and get great picture with. Take it up on the roof with you and plug it in right to the antenna and manually put the channels in.
I would be afraid that the Tv would fall off the roof and take me with it!
Just what I've been looking for.
Reactions: comfortably_numb
NBC coming to Watertown NY
Interesting ATSC 3.0 article
