One other piece on the path to 4K is having the correct LNB (3D2RB) for your dish. They are currently only available in the NY/PA area. This will expand in the future.The HR54 and HR44 are the same speed, they use the same CPU etc If you intend to go to 4K then the HR54 will be the one to get. You will still need a C61K client or a TVU with RVU capability. Although if you are not planning to go 4K immediately, it's possible that by the time you do there will be a DVR with "native" 4K support that does not need the client.
OR if you are fortunate to snag one off of eBay, WHEN available.One other piece on the path to 4K is having the correct LNB (3D2RB) for your dish. They are currently only available in the NY/PA area. This will expand in the future.
You bought up all the reverse band LNB's on ebay?Not anymore. I bought them all
Do they have another name? I just searched that name and only came up with a company in KY.Does anyone have experience with Reid Electronics out of Texas? They have good prices on receivers, but I've only bought from SS previously.
You bought up all the reverse band LNB's on ebay?![]()
I was trying to see if we had a laughing emoji(couldn't find one), because that's actually funny.Yup
Can't go wrong. At $40 they are cheaper than a SWM16
The Brooklyn seller is now up to $49.99Yup
except for the loss of its that I had with dish 622
Limited time offer
