HR54 | Page 2 | SatelliteGuys.US
HR54
Yes but unfortunately not with the new customer deals....!
The HR54 and HR44 are the same speed, they use the same CPU etc If you intend to go to 4K then the HR54 will be the one to get. You will still need a C61K client or a TVU with RVU capability. Although if you are not planning to go 4K immediately, it's possible that by the time you do there will be a DVR with "native" 4K support that does not need the client.
One other piece on the path to 4K is having the correct LNB (3D2RB) for your dish. They are currently only available in the NY/PA area. This will expand in the future.
Does anyone have experience with Reid Electronics out of Texas? They have good prices on receivers, but I've only bought from SS previously.
There is actually one on eBay at the moment, there were two but I bought one :-) I'm convinced these people have no clue what they're selling
Install November 27 order said hr44 got a 54 without asking liking it a lot except for the loss of ota that I had with dish 622
If you didn't know you can add OTA with a 2 tuner module called the AM-21. It is bigger than the HR54 but does work with it.
Often on eBay under $50. DirecTV may still have available but it is officially discontinued so they may not.
DTV super frustrating...what reciever..
Commercial install
