So, if I want a H3 and want to keep one of my HWS, I will have to have a separate dish for the H3 and HWS?
does the hopper 3 output 4k via hdmi? or do you need the 4k joey?
I assume it supports the High Dynamic Range that Ive been reading about on all of these new 4K tv's?It outputs in 4K![]()
DISH is actually not allowing people to upgrade at the moment, as they know people will be pissed if they get a Hopper with Sling and are stuck with it for 2 years when the Hopper 3 is coming out.
EDIT - What I said above is for existing customers. If you are a new customer I would wait until the H3 is released so you get one of those.![]()
So, no mixing of previous generations of Hoppers on same account.And a separate account.
Are they reading about the Hopper 3 ? Odds are they know nothing about it and will be just fine with what they have.My parents are going to be upset as they signed for dish on the 27th and got the hopper with sling.
YupI assume it supports the High Dynamic Range that Ive been reading about on all of these new 4K tv's?
You can back up your stuff to an external hard drive Also heard there could be a way to transfer from the old Hopper to the H3 using a Ethernet cable. But since the old Hoppers are only 100 m but I can only imagine that it will be slow to transfer everything is you have a lot of stuff.Id assume, since I could only have one H3 on my account and not with a HWS, to return my dual HWS's I could backup my recordings and then get an H3? We stay so far behind no telling when I could clear off a DVR drive.
BingoSo, no mixing of previous generations of Hoppers on same account.
Yes with a 211 or Wally.Maybe this was asked already, but can you still have a tailgate rec on your account with the h3?
Hopper 3 will be available this month and will be a zero cost upgrade for qualified accounts.
Back up timers to the remote and restore them to the H3Will there be a web based option or some kind of work around to import timers from those of us that have two or more Hoppers?
How many remotes will come with Hopper 3 and will the current remotes work with the this system? I currently have 5 TV's that will need to be hooked up.
I have separate timers on each hopper, its possible to back up both systems to one remote?Back up timers to the remote and restore them to the H3
Yes old remotes will work although the system is designed for the new 50.0 remote.
Limited time offer
