I hope so!thank you for being honest with me scott maybe in the future we will see those two come as apps i know that it wont happen i understand.
I missed it somewhere but what is the GO ?
You would need a second dish for the 211. When the Hoppe 3 is hooked up to the Hybrid LNB the Hybrid LNB goes into dp Z mode instead of dp X mode which the other older equipment used.
Only if you own it....Scott- thanks for the reply as I figured it would be that way. I really wouldn't need the 211k wired at my house but need to take it with me in summer. Can I keep the 211K active on account to take in summer without it hooked up at house?
Gerry
So I can't load it up from home and connect it to my dumb HDTV at the RV? <sigh>Its a portable hard drive / hot spot so you can download shows from your Dish DVR and watch them on a device running the DISH Anywhere app.
This month. JANURARY.
Yes OTA works and you will have 17 tuners.![]()
Scott, did you find out when the Carbon UI is coming out? I was would assume around when the new hooper comes out, but you never know
Does the go even plug into a receiver? They said it's a mobile device for hotel like situations when you're traveling I thought.
You can watch music videos on youtubei am some what disappoited we did not hear any music apps being mention you guys know which ones.so i wont bother telling you guys which ones i do not want to go on another vacation .
Highly incorrect.So if DPX is MoCA 1.1 (Hopper 1 & 2) and DPZ is Hopper 3, it looks like you can network any combination of Hopper 1, 2, & 3s on the new hybrid equipment (as MoCA 2.0 is backward compatible):
This should be fun.
Yes it does.Does the GO work with the HWS? Not that it matter to me anymore.
Yes but first step is getting the Hopper 3 and 4K Joey out the door.![]()
Highly incorrect.
When you plug in the Hopper 3 in, it turns off DP X mode on the LNB and is only DP Z mode.
So 2 Hopper 1/2s OR 2 Hopper 3s on DPH, right?
Negative. Only 1 Hopper 3 will work with the LNB.
That Hub you are seeing is for people who got a new Hybrid LNB and currently have two hoppers (or a Hopper and Super Joey.)
Limited time offer
