Hybrid is a very short putt from DPP. It isn't anything like SWiM.
As usual you don't know anything about it.
I think that's impossible to know until the new hardware is released. Maybe the new hardware will require the new LNB? I have to think there must be some extra functionality in these other than reduce the number of required cable runs from the Dish from 2 to 1. If not, seems like it wouldn't be worth producing different types of LNBs for economies of scale purpose.How would this LNB change that from the current setups? If that is possible with the new LNB, it's possible with the old LNB and the Solo/Duo nodes. Those can be purchased from Solid Signal, Amazon, eBay, etc all day long.
In what significant way does DPH effectively differ from a DPP LNB/Dual Node pairing?As usual you don't know anything about it.
SWiM breaks down bands into much smaller, transponder-sized bites rather than just stacking more bands on top of each other.
The way it differs is simple.In what significant way does DPH effectively differ from a DPP LNB/Dual Node pairing?
In the end, it appears that DPH is an economy as opposed to a functional difference. Economies are substantially for the provider's benefit and don't typically enhance the long-term customer experience. Have you heard lots of reports of failing nodes?The way it differs is simple.
You don't need an external Node.
I'm not the one arguing that DPH moves closer to SWiM. To me, DPH simply integrates two items into one in an inseparable way. Your discourse suggests DPH doesn't move any closer to something like SWM (again, looking at it from the customer's perspective)?It's BS the way you have to connect Hoppers and Joeys.
No reason to have external Nodes!
1 or 2 Hoppers ?? Com on, what is this 1995?
While install costs are a big part of the bargain, it doesn't seem like you gain much by moving part of one in-line device to the LNB assembly. The number of cables coming down from the LNB is the same so unless DPH is otherwise a big step up it is mostly a shuffling of the component deck. Where they used to mount a node, now they will mount a hub. Where's the savings?The simpler the install for the installers the quicker the installers can do it, allowing them to get more installs done in a days time, fewer parts and an excuse to cut the pay again to the installers.
For a standard install, cutting the number of coax cables in half is a big deal.The number of cables coming down from the LNB is the same so unless DPH is otherwise a big step up it is mostly a shuffling of the component deck.
DPH won't reduce the time involved in running cables. Two cables versus one from the same source to the same destination is not a big win. I acknowledge that the number of terminations might be reduced by two connectors in the event of a single Hopper setup but is that a "standard install"?For a standard install, cutting the number of coax cables in half is a big deal.
And in that sense, wen it cuts down on failures, it benefits customers, thus not being solely a benefit to the company, as Harshness was stating.I think this is a big deal because it should cut down on the number of failures due to multiple connections. It will help technicians too, I don't care if you think it's not a huge improvement or not, it will be appreciated. Cutting down on failures due to wiring is going to be a huge deal.
Well, I think this is a start to some better connectivity .I think this is a big deal because it should cut down on the number of failures due to multiple connections. It will help technicians too, I don't care if you think it's not a huge improvement or not, it will be appreciated. Cutting down on failures due to wiring is going to be a huge deal.
Given that you've replaced the node with a hybrid node and moved the stacking to the LNB, this doesn't seem to be a very strong argument.Cutting down on failures due to wiring is going to be a huge deal.
You are wrong.Well, I think this is a start to some better connectivity .
Harsh doesn't think so , Because he doesn't think Directv Swm is any Good.
And this to him feels like Directv Swm.
Wing dish as noted in Ziptied's post #37.I see they only require 2 Wires, what's the 3rd connection for on the LNB, a wing dish, or Can you run a VIP off it?
Limited time offer
