And some way of adding a second Hopper 3!I wish they would of addressed that one with the new hybrid lnb and solo hub. Would of been nice to have a one switch solution for sat and diplexing ota too.
Good idea, thanks.If you are so worried just buy a second to keep handy if the first goes, hook up, and activate. I just see no reason to need more than 16 tuners.
You still need 3 Ghz coax for H1 and H2 but not the H3, it only requires the 2150 Mhz RG6. DP/DPP stacks 32 transponders, DPX 48 transponders and DPZ stacks just 16 transponders, for now.How about the bandwidth requirement and sweep test to 3GHz for DPX? Are the DPZ requirements going up even higher? (I would expect so, but if not, then why not?)
Also Charles, you could get a 211 or Wally, add a second dish, I have thought about doing that to have some redundancy in case the Hopper goes down.Good idea, thanks.
Well, it looks like I already have to add a wing dish for 118.7. I wonder if DISH is going to move the International channels off of 118.7! If you add a second dish for a second Hopper 3, wonder if it could be combined somehow so both Hopper 3s could see each other!Also Charles, you could get a 211 or Wally, add a second dish, I have thought about doing that to have some redundancy in case the Hopper goes down.
Diplexing and MoCA don't mix particularly well and that's been the problem with diplexing on Hopper/Joey systems all along -- not the satellite IF. Stepping up to MoCA 2.0 (band bonding) certainly won't improve that situation.So will diplexing still be restricted?
ThanksDiplexing and MoCA don't mix particularly well and that's been the problem with diplexing on Hopper/Joey systems all along -- not the satellite IF. Stepping up to MoCA 2.0 (band bonding) certainly won't improve that situation.
Diplexing between the LNB and the node/hub should remain technically possible unless they repeated DIRECTV's brain fart where they put a control channel down low (2.3MHz).
Diplexing, like NTSC modulation, needs to be stricken from most everyone's long-term consideration.
Why would dish have the Cincinnati locals in SD on the western arc and the locals in HD on the eastern arc? Why do they even still have SD local channels?
Ok thanks. That's surprising though. I would think by now most people have hd TVs in their house, so they would want the hd feed.Because a good amount of people still only have SD equipment. That's why.![]()
Sadly they think by just buying the HD TV they automatically are getting HD.so they would want the hd feed.
If I were to have an H3 + 2 wireless joey setup, would that only require one line into house? With the access point plugged into the H3?
Amazing, thanks.
For those who are still using SD receivers. This is where the feces of customers owning their own receivers and/or dragging their feet on upgrades hits the impeller.Why would dish have the Cincinnati locals in SD on the western arc and the locals in HD on the eastern arc? Why do they even still have SD local channels?
Limited time offer
