Also found this if you want to turn the internal into an external by removing the 9 pin serial, and replacing with this: USB 2.0 A Male to A Female Socket Panel Mount Adapter
Also found this if you want to turn the internal into an external by removing the 9 pin serial, and replacing with this: USB 2.0 A Male to A Female Socket Panel Mount AdapterView attachment 111552
Posted new firmware 1248
1. Added Closed Captioning to IPTV
2. Added Multi-Audio for IPTV
3. Corrected some data base issues in satellites list
4. Green LED now blinks when recording or playback is on
Posted in the Online Upgrade. Will probably post the satellite update on Tuesday.Posted where?
How is work on the channel editor coming along? Is there an updated version available for testing? I miss being able to edit everything on my computer like I was able to with the GEOSATpro HD, or my older Viewsat & Fortec receivers...Posted new firmware 1248
5. Ability to backup channel list and settings to Internal Drive
(To update go to Menu > Manager > Version > Online Upgrade - then select Firmware 1248.
I am looking into this. Will update you in a day or twoInstalled 1248 and music choice channels have returned. Everything seems fine with the exception of the schedule recording is still not working.
No voiding warranty unless the board is damaged.I don't see a problem with doing that but I wonder if the vendor would void your warranty for doing so. I would imagine that it won't cause problems but it could void the warranty, at the vendors discretion of course. You're "safe" as long as nothing goes wrong with the product during the warranty period.
This is not coming as fast as anticipated. I am working on solution. What is good, the channel list structure is technically xml, so it's not complicated.How is work on the channel editor coming along? Is there an updated version available for testing? I miss being able to edit everything on my computer like I was able to with the GEOSATpro HD, or my older Viewsat & Fortec receivers...
Does schedule kick in on the internal drive for you? Also, did you make sure to mark it "record"?
In our testing the channel switched from another channel and recording started successfully.I tried both internal and external. The message comes up "going to record in 60 sec" but when the message goes out......no record starts on either recording device. Thanks.
Please indicate did you set schedule for Once, Daily, a particular day? What was the length of the recording set? Can you send a picture of the timer?
If the drive allows recording, it will allow timer.I tried both internal and external. The message comes up "going to record in 60 sec" but when the message goes out......no record starts on either recording device. Thanks.
Hmmm, is it possible then to edit the channel list with XML Notepad? If so, how can I get the channel list from the receiver and upload back?This is not coming as fast as anticipated. I am working on solution. What is good, the channel list structure is technically xml, so it's not complicated.
That would be a question to ask the vendor, but my post was liked by SatelliteAV, so I'm assuming he liked the idea, I know I was told it was OK to open and remove the internal USB drive, so this really isn't much different, you're not really modifying anything, just adding an extension to the USB port for easier access.I don't see a problem with doing that but I wonder if the vendor would void your warranty for doing so. I would imagine that it won't cause problems but it could void the warranty, at the vendors discretion of course. You're "safe" as long as nothing goes wrong with the product during the warranty period.
We do not void the warranty unless there is a damage to the main board. and yes i did like your idea, apparently.That would be a question to ask the vendor, but my post was liked by SatelliteAV, so I'm assuming he liked the idea, I know I was told it was OK to open and remove the internal USB drive, so this really isn't much different, you're not really modifying anything, just adding an extension to the USB port for easier access.
Limited time offer
