egnard How is it coming along with your Mini HD SE?
I haven't noticed the clock reset again, maybe one more time after I did my test. It has missed some recording events, but getting mostly all. I may have worked around a weak signal issue by adding additional timing events which tune into the channel a few minutes prior to recording event. (I figured the channel would be tuned in before the unit tried to record.) And I noticed a daily recording event was deleted from the timer list, I re-entered it, but only yesterday, so I'll see how that works out.
I also noticed that regardless of whether I designate that the receiver go into "standby" after the event in the timer program, the unit always shuts down. (I thought that by leaving the unit on it might avoid the clock reset, but that may not be an issue now.)
You know I did not even think of that before, but yes that could be a problem. There are only 8 timers. New firmware should be out in a couple of weeks or so that has expanded that to 20.
Actually, mine lists 20, so I probably already have the update, 2.0.91.
The audio works. The problem is no video if the Yamaha is on before the Mini is turned on.Perhaps the Mini HD is only putting out PCM audio, and the Yamaha receiver is expecting Dolby?
With the MicroHD, I set 1 minute in between back to back timers to help "pad" the time. Are you doing that with this receiver? I also have my time set to Manual, and never let it turn off or sleep. Depending on your dishes moving speed between the sats you are recording, you might have to set more pad time.
Actually, what bugs me more than this is the lack of closed caption. It's pretty hard to for me follow some of the BBC mysteries with Irish or Scottish accents. Anybody have a solution for this?
Hit the play button to show the progress bar. Then push the left/right button (beside the round center button) ((from memory))Something like...push the red button and the DVR jumps ahead 30 seconds
Limited time offer
