If I am thinking right I would guess about 5-6 hours in HD, that is assuming it works. Some flash drives I have tried in the past worked, some would choke.Any idea how long an HD SE can record on a 32 G flash drive?
Both are supported, but NTFS will have less indexing issues.
Limited buffer and throughput are the main reason thumb drives often don't work. Thumb dives are designed for file transfer, not for continuous data streams.
If my memory serves, YES, when it misses a signal, it says, "no" to recording.
If it completely reboots due to any issue, it will reset the clock.....find a Belkin 12 volt UPS to run it, and no worries ever come from power interruptions too!
It's really not a problem once signals are strong and consistent. I've not had the issue since I can't remember when....but was glad to know it CAME from the "no signal" situation. Can come from having the dish have to move a distance before starting, too...in which case, you can work around that. You won't find a box that keeps time without some help.......(the help being a $10 garage sale/craigslist 12 volt UPS for power blips) and NOT recording when signal is missing is a good thing. Saves space on a drive.The Amiko is a nice box, feature rich and hopefully it will grow on you.
My MicroHD still works nearly flawlessly, every single day automatically moving my dish to a satellite and recording. With the exception of the time slowly drifting, so I re-sync it once every two weeks.
Hypermegasat still has MicroHD's in stock
Limited time offer
