I just added 2 more recievers and when they were installed the tech used a seminar splitter instead of a swm switch how do I add ota to that setup?
I have no idea what a seminar splitter is. Adding ota to your setup is simple. Get an AM21 module, connect it to the receiver/dvr with the usb connection, plug it in, connect the antenna and watch tv!
Skipped a step there ...
Get an AM21 module, connect it to the receiver/dvr with the usb connection, plug it in, connect the antenna Run Set Up in menu's and watch tv!![]()
Stone,you mean you can't combine all 3 in one line but you can run a separate line for ota and it would work correct ?Note you cant have Swm + DECA + OTA
jmc98 said:I just added 2 more recievers and when they were installed the tech used a seminar splitter instead of a swm switch how do I add ota to that setup?
Its a swm-3 splitter not seminar can that be diplexed also don't need an am 21 as all TVs that are hooked to direct service have ota tuners in them and 2 recievers are h20's
Limited time offer
