how to add ota to a swm setup | SatelliteGuys.US
jmc98
822
43
32.750N 97.488W Fort worth Tx
I just added 2 more recievers and when they were installed the tech used a seminar splitter instead of a swm switch how do I add ota to that setup?
I have no idea what a seminar splitter is. Adding ota to your setup is simple. Get an AM21 module, connect it to the receiver/dvr with the usb connection, plug it in, connect the antenna and watch tv!
Skipped a step there ...
Get an AM21 module, connect it to the receiver/dvr with the usb connection, plug it in, connect the antenna Run Set Up in menu's and watch tv! :)
Details, smetails! :D Okay, run setup, THEN watch tv!
Its a swm-3 splitter not seminar can that be diplexed also don't need an am 21 as all TVs that are hooked to direct service have ota tuners in them and 2 recievers are h20's
I don't think you can diplex an ota signal with a swm. They have overlapping frequencies that will interfere with each other.
Would have helped, had you told us what recvrs you were working with in the beginning !
will ST have the giants vs vikings on monday night?
Random actions on HR24
