will this work? | SatelliteGuys.US
will this work?
They should screw right on. If not, it's easy to adapt.
One thing - are you CERTAIN that your existing Dish500 is Legacy and NOT DishPro?
They can NOT be mixed on the same system (I'm assuming you're trying to add a 3rd bird to your Dish 500 setup - if it's a second Dish 500 for separate receivers, then no problem at all).
Eugene Spot Beam and pulling a local?
Internal switches for x2x type receivers?
