Will Openbox work well on standard tv? | SatelliteGuys.US
larrchev
16
essex county canada
Hello
I have a 36" Sony Wega flat screen tv.Will a Openbox S9 work well on it.The tv has 3 regular video inputs and one composite.Thanks for any help.:confused:
If by "3 regular video inputs" , you mean component RGB ( red , green , blue jacks ) , then it will work just fine. The composite input would work, but only in 480i mode, and with a green tinge to the video.
My error brent,it has 3 standard audio/video input jacks and one set red,blue green and audio jacks. for connecting to a dvd player or digital set-top box (480i only)Hope this clarifies my query. Thanks.
I'd use the component (red/blue/green) for the Openbox. As Brent noted there is a slight green tint on the a/v outputs (known issue). Plus component can do other resolutions like 720 & 1080 which on a HD channel it looks very nice :)
Servo motor broke, great.
36" dish
