Being about same miles away from Nashville as you, but north instead of west:
(1) cost me over $100 in parts and labor to try to get HD OTA
(2) tried Winegard HD9095P antenna and Winegard AP4800 preamp 28db
(3) got FOX with 90 signal
(4) sometimes got WB and ABC with 55-78 signal that dropped out. Couldn't get the rest.
(5) worked out a deal ahead of time with installer to return antenna and preamp for full refund if he couldn't get all stations
(6) problem was that I am in a valley below road level plus partially blocked by hill 1/2 mile away. If you have flatter land and your neighbors are able to get the analog channels with an outdoor antenna, then you may be more successful getting HD OTA.
Actually it's 6.5 to 1 for normal 1080i. About 3 to 1 for 720p (at 30 frames and not 60 frames). If mpeg4 is used (for satellite HD channels) then cut that number in half.
As far as HD-Lite if the source has reduced resolution to start with and then upconverted to full 1080i then I would imagine some saving in the bitstream after it's compressed. An example may be PBS-HD which has half the normal bandwidth of normal HD this allows them to send both HD and SD subchannels.
Also on a last note. we may Babel get national hd soon. as soon as dish is done testing them. if we do and you are in a white area.. you should easily qualify with a waver.
I currently am grandfathered in for East and west distants and get CBS HD. If east and west big four HD is offered will the fact that I have distants qualify me for the other Distants in HD?
I asked that very question of a senior CSR. He said yes we would. But he was not sure if we needed to call to remind them to turn us on or if their system would do it automatically. I think it depends on where they put those feeds. For example, with CBS-HD you have to call since they are only on 61.5 or 148, and not many folks in Colorado have either of those dish locations.
