Which Satellite Finder will work? | Page 2 | SatelliteGuys.US
If it never found the 95 satellite then most likely it is the R10. You might reset it and then try again to auto detect and see if that helps, otherwise you will need to get a replacement.
Is there a way to force the upgrade to the software for the R10?
Installation Companies in Okla. or Texas
D* Whole House Server
