Which DVR to use with analog TV? | SatelliteGuys.US
JimMcC
580
Which DVR would you recommend to use with an analog TV(Sharp 32C540)?
Can I record satellite and OTA channels?
Will a DVR record digital and analog channels?
Thanks.
Dish Specific... if you want to record The Channels From Dish and OTA youll have to go with the HD DVR (942, 921)
If you just want to record the channels from dish (Locals, SCI-Fi, ETC).. if you only need one tuner ide say go with the 510... its a little archaic but it rarely has any problems.
Non Dish... If you want to record whatever you can stick on a Svideo or other cable get a Tivo.... Note that you will lose a lot of PQ and it will be slightly slower to change channels and such.
Dvr
Thanks Shadow. Are you sure I can't record OTA with any of the NON-HD units? Can I lease either one you mentioned, I'm an existing Dish customer?
I'm currently using the 811, but we just sold our HD set, so I don't need an HD receiver anymore. But, I like the fact that I can run my OTA antenna into the 811.
$19.99/3 Months Voom or New Sub Special Confusion?
Moving 148 dish to 61.5 - can't find the sat!
