Which button is Live TV? | SatelliteGuys.US
prashp1
31
CT
Hello. While watching Live TV, then pausing it or rewinding it. After awhile you decide to go to Live TV.......which button do you press for it? Instead of fast forward or skipping ahead? Thanks
there is no live tv button
I just hit the ff button then the skip ahead (the one that looks like >| )
that skips to the end
...or change the channel then hit recall. BUT you won't be able to rewind past the point you changed back
Live TV was one of the things I missed from E* when I switched to Directv. Like Iceberg said, just hit the FF button until you get to live TV.
A small subtlety, but to be clear for everyone, what Iceberg actually does is hit FF, then the 30-second Skip button, which will jump to the next tick-mark, or the end of the live buffer, whichever is first. If you are really behind, you can keep hitting the Skip to get to the live portion.
I also seem to remember reading in the user or quick start guide that you can hold down the Skip button to get to Live TV, but that has never worked well for me.
yeah i miss that from dish also
but i can buffer 2 streams now (when i remember how) :)
Guide Question
Serie Manger
