What have I got here? | Page 2 | SatelliteGuys.US
When using the Viewsat, don't forget to flip between channels 1 & 2 on the 4DTV to change polarities.
Galaxy 3C
TP Freq: 4040
Polarity: Horz
Scan Rate: 29110
No, you want a HiFreq Splitter that has power Pass on only one port. Otherwise both receivers will be sending voltage to the LNB.
since he has a old LNB the polarity is fixed by the 4DTV so it shouldnt matter. Otherwise just trun the LNB power on the Viewsat to "Off"
I did that on my Coolsat and it worked just fine...used the analog box to power the LNB and the Coolsat just tagged along
Success!!!!
OK, I did get my first sat programed and blind scanned. The downside is I am not sure what bird I am aimed at. I thought I was on 99.0W, but after looking at 'The List" I am not sure. I do receive numerous transponders with network programming, several that appear to be scrambled (GDMX). There is one Hispanic channel (4055 Galaxy-56).
Any ideas guys?
TIA
G16 C-Band
GDMX is on that satellite and so are a set of the networks from Puerto Rico/Virgin Islands
If you bring up the networks and press info it should tell you the transponder info. Should be something like
3844 frequency (can be off by 1 or 2)
H polarity
12298 symbol rate (again can be off by 1 or 2 or so)
GDMX isn't scrambled (although it might as well be, for a typical DVB receiver?), it's in 4:2:2 (some kind of video codec?), 4:2:0 is standard. But, you are on 99.0w.
Thanks bigtime to ya'll
Thanks guys and to think I've been sitti:)ng in the dinette looking at this BUD and wondering if I was ever going to get rid of it. I always kept it in running order was able to get a few analog channels, but they were getting few and far between. Sheppards Chappel and Gene Scott, NASA to name a few. It had its hayday and it looks like it is making a huge comeback.
Because of you guys and this forum I now have another interest to nurture in my retirement years.
I am pumped and I am h:):)ked!!!
How long have you had C band ?
DSR905 Question
