rv1pop said:Glad to have you aboard. How (or why) did get the receiver? There is a lot you can do, but to answer that question best, will require more information.
You are in the right place --- and first advice is to READ read, Read.
POP
You're going to need a dish. A 36 inch offset feed type to receive Ku band satellite channels. A MINIMUM of a 6 ft Prime Focus style for the C band satellites. You're also going to need a matching LNBF with linear polarization. For these, the site sponsors, listed on the top of the page, can help you out. Check out The LIST for available channels, G19 Ku has A LOT of foreign language channels. To see if you have LOS (Line Of Site) to the satellite(s) this link >> Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com Enter your coordinates and the desired satellite, Zoom in and see where the green line goes. It will also show the elevation so you can site along the path to see if it's interfered by trees, buildings etc.I want to know what can I do with it and how and what else I need?
I have a 4.5ft dish and a Viking universal LNB does that works for something?FaT Air said:You're going to need a dish. A 36 inch offset feed type to receive Ku band satellite channels. A MINIMUM of a 6 ft Prime Focus style for the C band satellites. You're also going to need a matching LNBF with linear polarization. [/URL]
That is appropriate for the job, if you are in the USA or Canada.I have a 4.5ft dish and a Viking universal LNB does that works for something?
FaT Air said:If possible post any info on the LNB(label?). I think it's Ku. And the dish may be a LARGE offset Ku. Great for a fixed 1 satellite system.* Post a picture of the dish. If there is any info on a label or molded into it, post that also.
concord said:
Anole said:The LNBF looks okay to me.
As for the big round dish in the foreground (to the right), it also looks fine.
It seems bigger than the ones used in Mexico.
The Mexican ones look a lot like the DTV dish in the background of your picture (to the left)![]()
Limited time offer
