Way to get ir to uhf pro kit to work with 21.0 remote | SatelliteGuys.US
s10zr2
241
3
Cincinnati, Ohio
Does any one know hoe to get the ir to uhf kit to work with a new 21.0 remote. The one it came with was a 10.1. I need it to work with the new 21.0 because my tv is new and the old remotes don't have the tv code in them. It is for a 211K box. When I had my 222 box the 21.0 remote worked fine with it, so when I purchased the ir to uhf kit I assumed it was the same uhf that was built in to the 222. I was wrong.
You need another 10.1 remote in order to make it work with the UHF upgrade kit. This is one of those rare exceptions when it comes to which remotes work with which receivers.
Big Question about DISH
EHD Listings
