Wall Mounting Advice? | SatelliteGuys.US
nicshow
8
I'm moving to Direct after being with Dish for many years.
We will be mounting 2 TVs to the wall with the wireless mini Genies. Is there a wall mount I should look for which would also serve to hold the mini genie?
Any other advice you might offer would be great!
Thanks,
Nic
There is a wall mount clip that I believe comes with the wireless minis.
If your using the wired ones, there is actually a bracket you can buy similar to the H25.
The minis are so small you usually can rest then behind the tv
SWM reading on D12
DirecTV admits to incorrect billing for RSNs
