W-adaptor | SatelliteGuys.US
W-adaptor
Turd,
You can always make a correct sized support arm out of 1x2x 1/8 inch wall aluminum tubing, using spacers on the arm's mount.
Even if the bracket were the right size to fit, the LNBFs would be spaced too close together. The spacing on the Superdish is much wider than the 500 or 1000.
SOAPNet to Top 60?
Homezone Manuals and Install Instructions
