[VOOM] Re: Wilt or others--need advice on receiving 1 out of 17 OTA channels. | SatelliteGuys.US
D
dacreamy68
Guest
Wilt,
I have the same problem with 17-3 in Albany, NY. Ever since the new
software download I can't receive 17-3 which is the HDTV PBS
channel. Called CSR in late August and had a service call soon
after. The installer came out and said I wasn't the only one in the
Albany area to have the problem. The installer said he would forward
the problem to VOOM. It's been over a month and nothing has been
done. Can you look into this?
Thanks,
David--- In VOOM@yahoogroups.com, Wilt Hildenbrand <wilth@o...> wrote:
> I'll get the guys to check into this a bit.
> Thanks,
> Wilt
> -----Original Message-----
> From: seattlesatelliter [mailto:seattlesatelliter@y...]
> Sent: Friday, September 17, 2004 2:27 PM
> To: VOOM@yahoogroups.com
> Subject: [VOOM] Wilt or others--need advice on receiving 1 out of
17 OTA
> channels.
> Sorry but this is going to be a bit long winded. Have been a VOOM
> customer since Dec. Had been receiving our local PBS HD ch. on
> subchannel 9-2 after 5 PM (prior to that other daytime programming
in
> SD). PG info always showed up on 9-5 without any picture. (When we
> had a Samsung HD setup prior to VOOM the HD signal came in on 9-5).
> However, for the past month and a half since the download of 6.10
> and/or 6.20(we believe) we no longer receive the HD signal on ch.
9.
> At 5 PM 9-2 goes blank and its PG says "Off Air". At that time 9-
5's
> PG now lists programming but no picture. I hadn't dealt with the
> problem for awhile since I'd been sick but last Sat. decided to try
to
> figure things out. Decided to check signal strength ch. by ch. on
9.
> When I got to the 9-2 having started with 9-1 and got to the Current
> Software page we had another freezeup. Did a 10" power button
reboot
> and started with OTA ch. 4 and worked my way up to 9-2 and there was
> the HD program in all its glory! Went back to ch. 4 for about 20'
and
> then back to 9-2 which now displayed "No Signal" again.
> Since we hadn't done an OTA scan with the new firmware we gave that
a
> try hoping it would resolve the problem. Afterward we had exactly
the
> same channels as before and still no HD on 9-2 or 9-5.
> Have talked to several VOOM CSRs since then and had a service call
> from Installs, Inc. (amazingly on time and professional this
time!).
> Michael from Installs assured us that we had a great signal on ch. 9
> as it was 98 on 9-1, 9-2, 9-3 and 9-4. He and his supervisor
decided
> not to touch the antenna (he'd been sent to see if our OTA antenna
> needed tweaking) and had no idea why we were not receiving an HD
> signal on ch. 9 (of course, since he was here around 11 AM ch. 9 was
> not broadcasting an HD signal although he saw an SD pic on 9-2 and
> "Off Air" on 9-5).
> Called VOOM again and the CSR suggested trying to reset the
resolution
> by using the infamous red button behing the door. Did so and did a
> power button reset. After this as soon as the program bar was
> available (couple of min.) 9-5 displayed "KCTS HD" but some time
later
> it had changed to "KCTS D5". Last night we checked for an HD signal
> on 9-2 or 9-5 with no luck.
> Forgot to mention earlier that a CSR had insisted we contact ch. 9
to
> make sure they were broadcasting an HD signal. I talked to their
> chief engineer last Mon. morn and was assured that they are from
> 5PM-2AM daily. They should know what they are doing as they were
the
> 3rd station in the US to broadcast in HD.
> Called and talked to a supervisor at VOOM a short time ago.
Described
> the problem in detail. She said we shouldn't be getting ch. 9 at
all
> since it wasn't listed on antennaweb. (I'll have to check that out
> but the last time we downloaded the stations ch. 9 was indeed
there.)
> Basically, since it isn't shown there we are out of luck. She said
> that she would send the problem in for research and will get back to
> us by phone within 72 hours.
> Sorry, I don't get it. 9-1, 9-2, 9-3 and 9-5 are all listed on
VOOM's
> PG and we received it from last Dec. until early Aug. and now it's
not
> available? Is it possible that the new firmware isn't recognizing
> 9-5? Maybe 9-5 is listed as a premium channel for which we haven't
> paid? I know all the premium channels are off the satellite but....
> Any ideas? We've run out on this end.
> Watching HDTV via VOOM (only) under partly cloudy Seattle skies,
Gill
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129gqq9ev/M=295196.4901138.6071305.300117
6/D=gr
oups/S=1705036932:HM/EXP=1095532046/A=2128215/R=0/SIG=10se96mf6/*http:
//comp
> anion.yahoo.com> click here
> <http://us.adserver.yahoo.com/l?
M=295196.4901138.6071305.3001176/D=groups/S=
> :HM/A=2128215/rand=713000499>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> http://groups.yahoo.com/group/VOOM/
> * To unsubscribe from this group, send an email to:
> VOOM-unsubscribe@yahoogroups.com
> <mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/> .
> [Non-text portions of this message have been removed]
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
[VOOM] Update: Re: Wilt or others--need advice on receiving 1 out of 17 OTA channels.
Just wanted to let the readers of this thread know that VOOM does take
reception problems seriously and wants us to be satisfied customers!
Although working with the CSRs has been less than fruitfull, Wilt put
us in contact with Peter who is trying to resolve the problem
receiving HDTV PBS ch. 9-5 here in Seattle. They are working with OTA
Motorola engineers to unravel the mystery. I'll keep you posted as
this problem gets resolved.
By the way, if any others in the ch. 9 reception area are having
problems receiving ch. 9-5 a post on here might help VOOM figure it out.
About to watch HDTV under mostly cloudy Seattle skies, Gill
Yahoo! Groups Links
Pbshd
Hi all,
I also was having problems here in Klamath Falls, Or. in getting PBS-HD
to tune in. Scanned just fine and was put into the PG as 8-1 (SD) and
8-7 (HD). Got a good pic on 8-1 and black screen on 8-7. Voom also
remapped the channels and got the same results. Have asked many, many
times for Voom to contact the engineer at PBS. He was never contacted!
However, he was also trying to help me so he ran many tests with me.
He knew that the problem was at his end as I was receiving CBS via OTA
in both SD and HD. He also says that his PSIP is correct.
Okay, to make a long story short, I now have PBS-HD.!! What he did was to
switch his broadcast from channel 8-7 to 8-1. I now receive HD on
channel 8-1 and am happy as all get out. Only problem now is that
I get a black screen on 8-7 (Just like before) but I don't need the SD
channel... He is closing in on why his HD is working on 8-1 but not on 8-7.
Moral of the story, work with the OTA engineers and not Voom and You'll
get more accomplished. Of course I live in a small town and from what I
can tell, am about the only person here that is getting PBS-HD via OTA.
Terry
L
RE: [VOOM] reception
D
[VOOM] Presidential debate on Voom?
