madpoet said:After he's done, I'd contact Installs inc about the cost for the second line.
-MP
I believe it is free.
-MP
Ken F said:You should be able to get two lines at no extra cost so long as the total cable run doesn't exceed 125 feet. They now specify 125 feet for a single receiver and 250 feet for two receivers, iirc.
Your off-air signals are strong. Not everyone has the benefit of strong, interference-free signals. Many folks have borderline signals on some or all off-air channels, and for them, the 4-6dB (or whatever it is) loss of the diplexor will make the difference between stable reception, and unstable reception or no reception at all. A good signal is fairly important to the VOOM box in my experience, because poor signals tend to cause more lockups.BUT i will repeat, if they set it up corectly you should not NEED seperate lines. I have a two box set up two lines only coming from the dish...each diplexed with the antenna signal....and no problems what so ever.....i was in the camp that thought the diplexor was the issue when i had problems at first, but it turned out to be the fact that i didn't need a pre amp on the antenna.
Trouthead said:Just left my house and the Voom installer. He has been installing since the C-Band days, but this is his first VOOM.
Asked him about running seperate lines for the dish and the OTA, and he showed me the work order that states one line to be run.
Told him I still would like two lines and how much extra, and he said $25.00. Don't know if it is too much, but it never pays to try and nickle and dime the installer. I said to do it. It is about a 70 ft run.
Will update when I go home to check on how it is going.
Ken F said:Sean,
Limited time offer
