Voom Channels-921,811 | SatelliteGuys.US
Ray S
256
Central NJ
Its 8/15/07 and I still have the Voom channels on these units. I purchased for the 921 and 811. I have DishHD ($20.00) and America's Everything Pack with Playboy and locals ($101.99).
I don't want to return either of these receivers for a leased one. I don't want a commitment. I just want a leased 722. What are my options? I will probably deactivate the 811. I have a 621 and 501 active. I only have two HDTVs.
I don't want to return either of these receivers for a leased one. I don't want a commitment. I just want a leased 721. What are my options? I will probably deactivate the 811. I have a 621 and 501 active. I only have two HDTVs.
i think you are a little confused one receiver numbers.
721? not the sd single tv right? i think u mean the 722 hd DVR 2 room system.
621? do u mean the 625 (sd 2 room dvr) or the 622 HD DVR 2 room sytem?
I think you have two options, you can keep the receivers and lease a new HD receiver from Dish network, that will require a 18 month commitment, if you return a receiver you receive a $10 credit for each one, personally I do not think its worth it , or if you buy for around $500 a HD receiver, then you will not have a commitment.
HD locals rollout schedule?
Dishcomm 222/722 Question
