Voom Box Horizontal/Vertical moving...??? | SatelliteGuys.US
truqui
336
Miramar, FL
I have a question regarding the Voom STB and these adjustments... :confused:
My HD picture, most noticeable on HDNews and OTA Digital (non16:9) is shifted to the left of my screen. I thought that the Horizontal/Vertical menu option was to make these adjustments but I can't notice them moving anywhere....
Any thoughts???
TIA
Are you using DVI? What type of set? My TV has seperate controls for DVI and component to shift the display left/right. I know my DVI is dramatically different than my component input.
madpoet...
I'm using DVI from the Voom box to 2004 Mitsubishi WS55413
I don't think it's the TV because everything els, DVD thru Svideo and Digital Cable thru Svideo are fine.
Sean...
Yes that's exactly what is happening...
So what you're saying is that I can't save it using the Voom STB?
Will they fix this as far as you know?
Thanks,
Harold
truqui said:
Sean...
Thanks,
Harold
Yes, Wilt passed it to the Motorola QA guys. It will be fixed...
What kind of OTA antenna does VOOM provide?
considering voom need some info
