VIP Receiver Top Warning Label | SatelliteGuys.US
j.vo
66
Dish used a super strong adhesive to place the don't move your receiver while it is plugged in label. What can I use to remove the adhesive without removing the paint?
I use a little bit of olive oil on a cotton swab. Just keep rubbing it unti all of the sticky stuff lifts. Then, take some alcohol and wipe off the excess olive oil.
I have always just used ordinary lighter fluid until I decided to stop removing that label.
Isn't there a better way...A tiny rant.
ECHOSTAR 14 119deg.
