viewsat9000HD and c-band dish | Page 2 | SatelliteGuys.US
sorry but you cant get ac3 audio with rca cables.you will need the optical cable to get ac3 then be hooked up to some surround sound system. i have also heard you can buy a ac3 decoder box but im not familiar with that device. hope that helps and yes i am getting ac3 sound with the optical cord with the vs9000hd.
it wont be ac-3 audio but you will get sound through the RCA cables on a ac-3 channel. All of the HD receivers have this feature. No extra equipment needed
Mapleleaf69,
Can you try with the VS 9000 see if you get sound through the RCA cables on a ac-3 channel.
Thanks,
DK
I have a Viewsat Max HD and the blind scan does not work on it and I have a Viewsat VS 2000 ultra and the blind scan works great on it.
HITS Quantum on AMC 4 at 101 West
question about splitter/combiners needed for ku
