Viewsat xtreme dillama | Page 2 | SatelliteGuys.US
As JSATTV has stated!Once you have your true south satellite programmed into the receiver using USALS you should be able to go to any other satellite in your receivers list and get a lock on it.This will only work well if the dish is set up correctly for the arc.
I changed the LNB TYPE TO universal/10600 I ended up loosing signal for some channels
Then I tried Standard /10750 and the same problem.Now I just left it as it is.
but to solve this problem do I have to delete all channels and then rescan!
Yes, you will have to rescan when you change your L.O.
OK so I scan and save. Do I delete my current channels that I have scanned then or will the receiver up date it self once the new scan is complete.
Also the first satellite to scan and save would be the closet to my true south correct
Yes go for your true south Sat first, and when you scan it in and save it you should have the number of channels that appear in "The List" or your not quite there yet. Also check your S and Q quality. The higher the Q the better the Signal will be.
The other thing I note's is that only few channels and some times only one on a specific sat will make the dish move to another sat why is that.
Prof7500 and TBS6981 using S2api5
Retro TV Beats Martha Stewart
