UHF antenna help | SatelliteGuys.US
UHF antenna help
VaberMan
34
Minnesota
Has anyone extended the range of the UHF antenna by moving it using coax cable. Here is my current set up
Upstairs I have one 722 connected to my HD tv and then the SD is split between three bedrooms (my children take turns with the remote).
Downstairs I have the other 722 connected to my HD tv and the SD feed to the master bedroom.
I want to split the downstairs SD feed to my three season porch in my back yard about 50 feet way but the remote doesn't have the range to change the channels.
Any suggestions would be greatly appreciated.
I will have alum siding, my computer room and one level to navigate through. I will move the antenna until reception works from both the porch and bedroom. Thank for all the help.
? about moving, literally
dish kinda sees my 119...
