Nope, still not working on my 4K Joey yet. Not Netflix on it yet either.Can you use the sports bar mode from a Joey 4K?
Sent from my iPad using SatelliteGuys mobile app
Does anyone else have the rebooting Joey issue when watching Netflix?
Sent from my iPhone using SatelliteGuys mobile app
Joeys don't do PIP, sports bar mode is only on Hopper. (thanks for the info, Chad!)Nope, still not working on my 4K Joey yet. Not Netflix on it yet either.
I'll just bet you are!(I am on a different software version so I can't check)
(This thread was/is for Hopper 3) There is no way to force an update - the only thing we can do is make sure the Hopper and all other receivers are idle overnight - in "standby" mode and NO recordings happening.Is there anyway to force an update? I am still running one from 3/2/16 u255
Glad to hear that. Now they need to fix the empty folder issue.Well U307 fixed my disappearing folder problem. I'm happy now.
Awesome!Well U307 fixed my disappearing folder problem. I'm happy now.
if you press the search button/ magnify glass do you see shows or just channels? Do you still have timers?Is it possible to accidentally turn off prime time anytime? It says it's on but it did not record a whole bunch of stuff last night.
That was the problem. When I would transfer a recording to an external hard drive or watch all the shows in a folder the folder would disappear when it was empty. But the folder would still be available and would re-appear if I set a timer to record a show directly into the folder or moved a recording from the main DVR directly to an empty folder. This morning I noticed that 1 of my empty folders was again shown on the 1st DVR page.Glad to hear that. Now they need to fix the empty folder issue.
Limited time offer
