Twinhan 1022A W/ Coolsat Pro | SatelliteGuys.US
raydio
K6KGW
987
982
Rio Rancho, NM
I just installed a 1022A into my Sony computer and slaved it to my Coolsat Pro. I am on IA5 and scanned a transponder and have a list of channels. But when I try to view any of them I get a Fail To Play Your Program message. What is that about? I am using the stock software to begin with to shake out the bugs. Thanks for the help.
Ok, I have an image when I select a channel but it's like a screen shot...no moving video. Also no audio. I don't have an external video card, the box has the video on the motherboard. Can I get away with this?
If you have decent computer specs I don't see why a built-in video card wouldn't work. You may wany to try MyTheatre or another program and see if you get better results.
I tried MyTheater and that did not work well. I settled on ProgDVB. That works well with my computer and does 4:2:2 very nicely!
The Pentagon Channel on G10
Review: DMS International 50mm tube for SG2100
